| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Groups with a plate as main part will not be updated if the mainpart is changed in size.
The groupname will show a different name as the mainpart regarding the size.
The same can happen for groups with a shape as main part if at creation of the group the option use main part data is not activated.
The tool PST_Update_Groupnames can synchronize the name from the mainpart to the group name.
