| Product(s): | PowerProStructures | ||
| Version(s): | S8 | ||
| Area: | ProSteelTools | ||
| Subarea: | N\A |
After starting the tool select the objects which should be changed.
Now it is possible to change the layout for radius and holes.
More options are available to change:
For all parts it is the display of centerline, part label, ElementCoordinateSystem and transparency.
For shapes the visibilty for COG line, Pitch lines and 2D section can be changed.
For plates it is an option to switch the grid on or off.
| Original Author: | Steffen Knoll |
