| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Starting the weight tool, select objects and confirm. Now the same sums as in previous versions will be shown
including weight without bolts and for all bolts.
Loading details more categories are available. Here some examples:
Category Material. Standard sorting order is by weight.
Category display classes sorted by index.
Category shapes by shape type sorted alphabetically. For shapes also the total length is displayed.
Category plates by thickness. For plates and grid plates also the top sufrace will be shown as well as the
current calculation method.
