02 Path and file name for export file
In the lower part of the frame Paths, the export path and file name are to set up.
Available for the export path:
-part list path of the current workspace - autmatically filled in
-path of the current model - also automatically
-other path - any path can be choosen
Below that come the options for the file name.
Here it is also possible to create the name automatically by using the model name with options to
add date and time of the creation of the file.
For saving templates it would be ideal to use the automatic functions.
This way a manual set up after loading the template would be obsolete.
Here a sample with the automatic file name.
