05 Excel file creation
To start the excel export file creation use the Ok button.
After that to process bars will be displayed visualizing analyzing the model and the actual export.
When the export file creation is finished, two more options appear:
    - to open the export file in Excel
    - to hide all parts that are part of the exported excel file
Both will be done when leaving the dialog by the Ok button.
Only parts with a position number will be exported.
Order of the list is always by position number starting with the lowest.
