| Product(s): | ProStructures for AutoCAD | ||
| Version(s): | For all ProSteel for AutoCAD Versions | ||
| Area: | Settings | ||
| Subarea: | Options |
PS Properties is not showing up in the right click context menu
4. When you Select a ProSteel Object and do a right click you should see the PS_Properties
| Original Author: | Roger Belen |
