| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
In this case make sure to enable these two AutoCAD settings (with explanations from AutoCAD Helpfile):
FILEDIA: "Suppresses display of file navigation dialog boxes."
CMDDIA: "Controls the display of the In-Place Text Editor for the LEADER and QLEADER commands."
Both values are initialy set to 1 (ON).
