| Product(s): | ProSteel for AutoCAD | ||
| Version(s): | All Versions | ||
| Area: | Object Display | ||
| Subarea: | N/A | ||
| Original Author | Sandip Kar, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
In the shaded mode, the structural objects are appearing as distorted in ProSteel for AutoCAD as shown in the below image.
Please follow the below steps to resolve this.
1. Select the object and right click then click on the PS Properties.
2. Under the General Data > Layout page, enable the Modeller and Solid Kernel options then click on the OK button.
3. Now, we can see the Structural Object perfectly in shaded mode.
