| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
In order to plot a large number of drawings (e.g. singleparts) you might want to use the Batchplot-feature.
Prepare the format file (frame DWG)
Open the required frame DWG, start the plot dialogue in the model area, edit your adjustments incl. plotstyle (1);
save it as Setup with any name (2); execute on the present layout (3). Save the frame DWG this way.
Now start the Detail Center Express on your model; it creates the desired (singlepart-) drawings.
Then start the batchplot via AutoCAD/ File/ Publish.
Delete all entries here in order to load a new batch of drawings.
Exclude the layouts (1) and add the drawings via +button (2). It is important that there are no errors shown beneath "Status" (green check mark); this should be warranted by step 1. Finally start the batchplotting by clicking the button "Publish" (3).
