| Product(s): | ProSteel for AutoCAD | ||
| Version(s): | For all ProSteel for AutoCAD Versions | ||
| Environment: | Windows 7 64 bitProStructures, Autocad, ProSteel 3D Professional | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
New, or moved objects don't appear or appear at the old position when using
visual styles.
This seems to be related to a few graphic cards.
Here a solution how to avoid this problem.
Start the command CUI via the command line.
1. Search for visual
2. Select the command you are using.
3. Click in the macro field
4. Open the macro editor
Add "PS_RESHADE " at the end of the macro. It is to important to have a free space after PS_RESHADE
Do this for all visual commands you are using.
Than test the commands. PS_RESHADE should automatically be performed and avoid any displaying differences.
