| Product(s): | ProStructures for AutoCAD | ||
| Area: | Units and Measurements | ||
| Subarea: | N/A | ||
How to change units in ProStructures for AutoCAD.
1. Once you open the application type ‘Measurement’ in the command line as shown below and press enter.
2. Now, use value “1” for Metric Drawing units and “0” for imperial Drawing units.
By this simple method, you can change the drawing units in the application.
