| Product(s): | ProStructures for AutoCAD |
| Version(s): | N/A |
| Environment: | N/A |
| Area: | AutoCAD |
| Subarea: | Menu |
| Original Author: | Roger Belen, Bentley Technical Support Group |
ProStructures Menu Missing
ProStructures.cuix file needs to be loaded
From the AutoCAD command line Type in Menuload
2. The Load/Unload customizations dialog box will open Click BROWSE
Browse into the location of ProStructures.cuix file located under
C:\Program Files\Bentley\ProStructures\V8i_version\AutoCAD version\Localised\English\Menus
Note: Location varies depending on the version of ProStructures, AutoCAD and loacalisation used.
3. Select the ProStructures.cuix file, Click Open and LOAD
4. Close the Load/Unload Customizations Dialog box, then you should now see the ProStructures Menu
communities.bentley.com/.../autocad-platform-not-supported-for-prostructures-connect-installation
