| Product(s): | ProSteel | ||
| Area: | Setup & Customization | ||
| Subarea: | Menus | ||
The ProStructures menu as well as ProConcrete and ProSteel ribbons are missing in ProStructures for AutoCAD.
ProStructures.cuix file needs to be loaded to see the ProStructures menu as well as ProConcrete and ProSteel ribbons.
1. Type MENULOAD and hit Enter key.
2. Load/Unload Customizations dialog box will open, click on the Browse button to load the ProStructures.cuix file.
3. Now, browse to the below location and select ProStructures.cuix and click on the Open button.
DriveName:\Program Files\Bentley\ProStructures CONNECT for AutoCAD\AutoCAD <Version>\Localised\English\Menus
Note: Location varies depending on the version of ProStructures for AutoCAD, AutoCAD and localisation used.
4. Now, click on the Load button and then close the dialog.
5. Now, we can see the ProStructures ProConcrete and ProSteel ribbons.
6. To see the ProStructures menu, type MENUBAR and hit Enter key then enter new value 1 and hit Enter key again.
In this way, we can bring the ProStructures menus in the ProStructures for AutoCAD.
