| | Applies To | | |
| | Product(s): | ProSteel | |
| | Version(s): | N\A | |
| | Environment: | N\A | |
| | Area: | Filtering | |
| | Original Author: | Steve Crabtree, Bentley Technical Support Group | |
Use Process Status to find elements in a model
You can use Process Status to find elements in the model that have had a specific process assigned to them.
How to use Process Status to Filter Model
- Go to the menu and Select ProStructures > Process Status…
In the ProSteel Process Status dialog click the “Edit process status table” icon
- Add a new process status category. Save and Exit the dialog
- As you make modifications to the model set the Process Status with the desired status.
- To user Process Status to select elements with a specific process status select the Process Status from the menu.
- Select the icon for “Coloring of parts according to their process status” use Select All and the elements in the model will be highlighted.
ProStructures Wiki
