Document Type: TechNote
Product(s): Prosteel
Version(s): All ProSteel/ProStructures Versions
Original Author: Roger Belen , Bentley Technical Support Group
This is the solution on how to have Units/Values in Metric with Shapes Display Name in Imperial
(See image below)
2. To change the file from showing the display name as Metric please see images below.
3. Change Automatic to IMPERIAL
4. Noticed the properties of the shape. The Shape is shwoing as Imperial shape as the Display name but the values are in Metric.
