| Product(s): | ProSteel | ||
| Version(s): | N /A | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
Usually the surface of the ProSteel Shapes are taken from the resp. table and displayed in the singlepart lists. In some cases you may need the surface of just a singular region of the entire shape. Here is a workaround.
The requested ProSteel Shape has to be copied, transformed into an ACIS volume (PS_CREATE_ACIS) and exploded by AutoCAD command; then the singular (AutoCAD-) regions can be measured:
Bentley's Technical Support Group requests that you please confine any comments you have on this
Wiki entry to this "Comments or Corrections?" section. THANK YOU!
