| Product(s): | ProSteel CONNECT Edition | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
This tool can be used to export the project information in the Excel format where default sample excel template is provided in the ProSteel. This default excel file can be edited by putting required project data and exported.
This wiki explains the steps to use this tool.
Note: This tool is compatible and only works with ProStructures CONNECT Edition Update 5 and onwards.
1. Navigate to the ProSteel tools and select the tool and this will open a dialog box for it.
2. The each step to export the excel file is explained in the following Links:
