| Product(s): | ProSteel | ||
| Area: | ProSteel Tools | ||
| Subarea: | N/A | ||
‘PST Subpart Level Same as Main Part’ tool can be used in the group, when we need to assign level subpart same as of the main part.
This wiki explains the steps to use this tool.
Note: This tool is compatible and only works with ProStructures CONNECT Edition Update 5 and onwards.
1. Navigate to the ProSteel tool box and select the tool.
2. Select the parts to which you want to apply this tool and then level assignment for those sub parts will get updated. (Refer the images below for better understanding)
