| Product(s): | ProSteel 3D Professional | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Product Advantage Group |
Controlling the views within Power ProStructures is a great way to optimize the usage of the software. In Power ProStructures you can use the command Object View to manipulate the view easier and gives you more speed and accuracy working within the model. Below is a demo video on how to use this command.
To go into the center of an element by using Object View Centered or work onto the face of an object by using the Object View at a Point Command.
