| Product(s): | ProSteel |
| Version(s): | CONNECT Edition (10.xx.00.xx) |
| Environment: | N/A |
| Area: | Detail Center & 2D Drawing Creation |
| Subarea: | Detail Style |
| Original Author | Sandip Kar, Product Advantage Group |
How to display the Grids or Axis in 2D Drawing views?
The Workframe Axis which is also called Grids, can be easily displayed via Detail Style in the Detail Center. Please follow the below simple steps to get this displayed.
1. Open 2D Detail Center navigating under Steel Workflow > Drawing Production > Detail Center Standard.
2. Open the Detail Style. You can directly open the Detail Style from the Detail Style box or go to View Tab and Select the View, Right Click and say Edit Style
3. When opened the Detail Style, Navigate to Description > Additional text > views and then in that dialog enable Display axis, With axis lines. See the below snap.
Also as shown in the above image, one can control the Text that means Grid bubbles from the origin changing the value of Text Distance.
4. The final result will be like as below
In this way you can display the Grid or Workframe Axis in 2D Drawings.
