| Product(s): | ProStructures, ProSteel |
| Environment: | 2D Detail Center |
| Area: | Descriptions |
| Subarea: | Language |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to change the language of the labels or information displayed in Title Text of 2D Drawings
1) In the Parts tab of the 2D Detail Center-Standard environment, right click in the blank area of the Detail blocks section. Then choose Additional Functions > Edit Translation
2) In the Edit Translation dialog box, click on the Append a new language button and then type in the name for the respective language you wish to add and click OK
3) Now add some of the available titles by selecting them from the section on the left side of the dialog box. Here you need to manually type in the translation of the selected title description and then click on the Add Translation button
4) Now, assign a detail style to the block and then Edit the detail style. Here, in the Descriptions option, go to the Additional text tab and in the Language section, choose the language parameters and set them as required
5) Finally, Save the detail style and Update the preview
In this manner, you can manually add translations to frequently used title texts and add them to your 2D drawings in ProSteel CONNECT Edition
