| Product(s): | ProSteel 3D Professional | ||
| Version(s): | All | ||
| Area: | ProSteel Options | ||
| Subarea: | Dialog Settings | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group |
In order to make the ProSteel surface a bit more comfortable here two tips for your ProSteel Options.
This appearance is controlled by the ProSteel Options, Dialogue Settings (see next step):
Coloured Icons make the appearence a bit more pleasent :-)
