| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
All AccuDraw shortcuts on the left hand are moved under the key A now.
So using key A the submenu for AccuDraw functions is displayed.
For T for top it is now AT and so on.
Also two additions to this submenu.
1. Q set origing. This one is preset on O, but as it is on the right hand that isnt efficient.
2. Space for Change Mode. This one is in CONNECT Edition on M, so also on the right hand.
Per A and then space the mode toggles between x,y,z and angle mode.
To find under File/Settings/User/Keyboard Shortcuts
The next picture displays the new block A for AccuDraw.
And dircetly below the block with all shortcuts for the Workflow PS_compact.
