| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
For setting up the workflow PS_compact, download following zip file.
communities.bentley.com/.../PS_5F00_compact_5F00_V4.zip
The file consists of the two files:
PS_compact.dgnlib - This file contains the workflow with all tool groups
Personal.KeyboardShortcuts.xml - This file contains all Keyboard shortcuts for the AccuDraw Group A and for the display of all tool groups.
This file needs to be copied into the organization folder for dgnlibs/GUI.
Usually the path is:
C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\Organization\Dgnlib\Gui
Depending on the used installation options this might be a different path.
You can check the path in ProStructures.
Go to Files/Settings/Configuration/Configuration/Variables
Search for GUI.
The path list for MS_GUIDGNLIBLIST should include one path under Organization.
This file needs to be copied into the personal settings folder.
C:\Users\username\AppData\Local\Bentley\ProStructures\10.0.0_1\prefs
But also this path can be different. To find the correct folder the easiest way is to use the key-in in ProStructures with:
$ % explorer $(_USTN_HOMEPREFS)
Now press Enter and an Explorer window with the prefs folder will appear.
Now you need to restart ProStructures.
The workflow and all shortcuts should be available now.
