| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
First steps are to insert a new tab and under the new tab groups.
The best choice for inserting tools is the option "Commands Application" under Choose components from.
There is no possibility to search for a tool but keying in the first letters makes the list jump to the next entry starting
with those letters.
Inserting happens via the Add button to the position below the current position on the right.
The position can be adjusted via Drag&Drop or per the arrow buttons.
If a tool cannot be found directly it might be worth using the serach feature in ProStructures on the upper right hand side.
Like here the search for pattern.
