| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
The keyboard commands are still missing to display a tool group directly at the mouse.
How to get to the Keyboard Commands dialog was already described in 3 AccuDraw Changes.
Keyboard commands may only occur once on the respective layer.
The following command input is required to call tool groups:
ribbon grouppopup PS_Compact\Standard\Connect V
So
ribbon grouppopup
as command call and
as
workflow tab\tool group
