| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | Workflow |
| Subarea: | PS_compact |
| Original Author: | Steffen Knoll, Bentley Product Advantage Group |
PS_compact is therefore a workflow with only one tab on which all the necessary functions are grouped together.
Since command invocation within DropDown menus does not work reliably, the most important commands are available with
the main tool and the DropDown menu beside.
For example the normal endplate can be called with EE and the dropdown for endplates with ED.
So the second letter is always a D for Dropdown and the direct command is always the same letter twice.
When entering TED the dropdown opens and the desired subitem must be selected with the mouse.
