| Area: | Installation | ||
| Subarea: | Error | ||
In this wiki, we are going to learn how to resolve the issue when we get the ProStructures Install Error Code 0x80070643 while installing the ProStructures application.
Cause of Error 0x80070643: There might be various reasons for this trouble. The Update Database got corrupted, the .NET framework needs to repair, the system file is missing, etc. are the possible culprits for the ProStructures installation Error 0x80070643.
Please follow the below methods to resolve this.
Method 1: Restart your system
In many cases, most of the errors get fixed simply by restating the system. Hence, try this one and see whether this issue has been resolved or not. If not then try out the next option.
Method 2: Restart the Windows Installer service
The wrong configurations under the Windows Installer service sometimes generate the installation error 0x80070643. So restarting this service might resolve this issue.
1. Type Services in windows search and left-click on it to open.
2. In the Services dialog, restart the Windows Installer service.
3. Now, try to install the ProStructures application. This time you might not get this error.
Method 3: Repair .NET Framework
When none of the above fixes help you to solve this issue, then the .NET Framework file might have gone corrupted.
In this case, use the .NET Framework Repair Tool to fix this or install the latest .NET Framework.
In one of these methods, I hope this issue may get resolved. If you still facing this issue then kindly log the service request for further assistance.
