| Area: | Key-in commands | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
Key in commands are available within Power ProStructures.
Some commands are not available within the Task bars or Icons but are accessible using the key in commands. Some of the example are:
2. Key-in the commands
ProStructure_Reload_References - updates and reloads all shape databases
ProStructure rebuild has several options to clean up a drawing having possible inconsistencies.
Enter ProStructure rebuild, press enter and type the options
60 to rebuild elements in the drawing
51 to clean up the drawing and get statistics
41 for updating Graphics and non reacting elements
Another Key-in is
SET RANGE: for better working accu snaps in pure MicroStation drawings.
ProStructures Key-ins
ProConcrete Key-ins
