| Product(s): | ProConcrete |
| Environment: | N/A |
| Area: | Drawing Production |
| Subarea: | Detailing |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
When working with congested drawings, one may need to hide certain unwanted 2D rebar elements while detailing, to have a clean or organized rebar drawing
This document will explain the process to hide a 2D rebars in the drawing model
1) In the ‘Drawing Production’ tab, click on the ‘Quick Edit’ tool
2) In the ‘Quick Editing’ toolbox, choose the ‘Hide Bar’ option
3) Now, click on the ‘Edit selected bar’ button and choose the rebar that you want to hide
4) Then select the rebar for which you want to hide
In this way, one can use the ‘Copy Bar Label’ tool to quickly add labels to the 2D rebars in your drawing model for detailing
communities.bentley.com/.../how-to-add-custom-rebar-annotation-labels-as-presets
