ID Title
| 1055426 | imodel publishing for 2.0 format and Bim Bridge is implemented |
| 1109097 | The rebar and concrete bar data are always loaded into the Manual Marking dialog box |
| 1113971 | PolyCut Openings are not disappearing when the Polyline was in offset after a model file reboot |
| 1124410 | PS Modification Properties are now exporting to the bim file |
| 1125191 | Group data is a property now in the .bim file format |
| 1106179 | AutoLabels - The Label position is not shifted in the output drawing |
| 1086920 | 3D group export command is being extended for the IFC export |
| 949957 | copied model work-frames are displayed in the select view dialog |
| 1131632 | MicroStation Connector is not anymore reported instead of ProStructures Connector in iModel Repository when an iModel is published using key-in. |
| 1126425 | Mechanical devices are created on the same level as the 3D rebar. |
| 1127415 | iModel bridge workflow for BAS is implemented |
| 1120914 | Drills on the top flange appear always correctly when a welded shape is dropped. |
| 1120915 | 2D details of flange plates of welded I shape shows both flange holes accurate |
| 1120919 | Welded I shape top and bottom plate get different numbers when needed |
| 1120935 | In drawing part list of welded I shape 2D detail shows correct plate thickness |
| 1111528 | AutoLabel - Copy bar attributes from dgnlib to output dgn is now implemented |
| 1123305 | Fudge Bar dialog - Distance and multiplier options are localized. |
| 1124049 | Export Item Types attached to ProConcrete Shapes and Concrete Solid Reference to IFC is implemented |
| 1124050 | Export Item Types attached to Single Rebar, RebarSets to IFC is implemented |
| 1124412 | Anchor Bolt properties are exported to bim file |
| 1124473 | Bolt properties are exporting to bim file |
| 1124462 | Base Plate Dowel Properties are exporting to bim file |
| 1094855 | ProSteel: Stiffener Distribution tool works for Welded shapes |
| 1113512 | Hole diameter text is correctly sized when we create a 2D drawing via DC Express with the border frame which has an annotation scale greater than 1:1 |
| 1106499 | Stiffeners on Welded I-shapes get resized based on change of the section size |
| 998545 | Batch export of individual Groups / Sub Groups / Assemblies to separate IFC file with metadata is implemented |
| 1118832 | Rebar is not placed outside of concrete wall boundaries after updating wall reinforcements |
| 1114957 | Fudging/nudging 2D bars implemented |
| 1113743 | PolyCuts are implemented with Irregular dispatch reinforcing rebar set |
| 1102726 | In Concrete Partlist the position number is sorting properly in ascending order in all cases |
| 1113155 | NC Data – Drilled holes are appearing in NC Viewer for Bent Plates correctly |
| 1119297 | Match & Extend - Wall footing is getting placed in the correct location with Imperial units |
| 1119397 | Match & Extend - In T joint wall it's possible now to select the Rebar direction for 2nd leg |
| 1119401 | Match & Extend - In T joint wall, 2nd leg is taking anchorage length correctly |
| 1119407 | Match & Extend - Previously used End condition data must not be cleared from the Single rebar distribution dialog before rebar getting placed |
| 1115401 | AK block of bend plates is accurate |
| 388782 | option no subpart grips when plotting is working |
| 1097894 | One can use text styles from dgnlib in ProStructures for Shape labels |
| 939083 | Add single tie in a circular concrete column is implemented |
| 1093369 | Improved right-click behavior in Detail Center |
| 1098428 | Stiffener distribution tool is working with straight welded I-shapes |
| 1008423 | PolyCut RebarSet – PolyCut is created on the RebarSet if its parent concrete element is Pad footing |
| 1008426 | PolyCut RebarSet – PolyCut is created on the RebarSet if its parent concrete element is Continuous footing |
| 876101 | Circular MS solid elements can be reinforced now with any of the special reinforcement types |
