| Area: | Administrate Groups | ||
| Subarea: | Groups | ||
In this wiki, we are going to learn how to dissolve the existing groups. To dissolve the existing groups, we need to use the Dissolve Group tool shown in the below image. Basically, it will take the elements out of the group and make the parts to single parts
1. Under Steel workflow, navigate and left click on Groups located at Home > Classification > Groups.
2. Administrate Groups dialog box will open, click on “Dissolve Group”. See below image.
3. Now, click on the existing group to dissolve it into single parts. One pop up will come just click on OK button.
4. To check whether group is dissolved or not go to PS Properties. In PS Properties dialog box, there is Group Data tab will get disappeared and when you select on parts only single part will get highlighted. See below image.
In this way, we can dissolve the existing group using Dissolve Group command.
