| Area: | Administrate Groups | ||
| Subarea: | Groups | ||
This wiki explains how to delete the existing groups. To delete the existing groups, we need to use the Delete Group tool as shown in the below image.
1. Under Steel workflow, navigate and left click on Groups located at Home > Classification > Groups.
2 . Administrate Groups dialog box will open, click on “Delete Group” tool. See below image.
3. Now, click on the existing group which you want to delete. It will erase entire group. See below image.
In this way, we can use Delete Group tools to delete the group.
