| Area: | Administrate Groups | ||
| Subarea: | Groups | ||
Once group is created one way is to edit the group is by using Edit Group Data tool. We can change various parts of the group information by using this tool. This wiki explains how to edit the existing group data by using the Edit Group Data tool.
1. Under Steel workflow, navigate and left click on Groups located at Home > Classification > Groups.
2. Administrate Groups dialog box will open, click on “Edit group data”.
3. Now, select the existing group, then the “Group Properties” dialog box will open. We can see in the below image the whole group is highlighted. In the Data we can add information as well as can give assignment to the groups.
Note: These input fields can also be accessed via right-click > PS Properties > Group Data and click on Data. Notice that when you click on data the whole group will be highlighted.
In this way, we can edit the group data using Edit Group Data tools.
