| Area: | Administrate Groups | ||
| Subarea: | Groups | ||
If a group is already been created, we can add or remove parts from the group by using following tools as shown in below image. This wiki explains how to add parts to a group by using the Add Parts to Group tool.
1. Under Steel workflow, navigate and left click on Groups located at Home > Classification > Groups.
2. Administrate Groups dialog box will open, click on “Add parts to group” tool.
3. Now, click on the group first and then click on the part which you want to add into the group.
4. Go to PS Properties to check parts is added to the group or not.
In this way, we can add parts the group using the Add Parts to Group tools.
