Add Part To Group Not Working
 Product(s):ProStructures
 Version(s):CONNECT Edition (10.XX.00.XX)
 Area:Administrate Groups command
 Subarea:Verify
 Original Author:Steffen Knoll, Bentley Technical Support Group
Updated By:Vyanktesh Nama, Bentley Product Advantage Group
Problem Description
A single part can't be added to a group.
Reason
Part has redundant group information. That happens for example when the main part of a group has been deleted.
Steps to Resolve
1. Open Administrate Group command from Steel workflow > Home > Classification > Groups.
2. Go to Verify tab, Start check parts by selecting the button as shown in the below image.
3. In the Message Center, you can check the results.
4. Unhide all parts by selecting Regenerate button located at Steel Workflow > View > Display Tools > Regenerate.
