| Area: | Administrate Groups command | ||
| Subarea: | Groups | ||
This section contains the wikis related to the Groups tab of Administrate groups command in ProStructures CONNECT Edition. Groups can be used for different reasons. Often used for drawing production to View and detail several parts together at once. We can modify the existing groups and can edit the properties of groups as well.
A] Create/Delete:
B] Count:
