| Area: | MicroStation CONNECT Edition Basics | ||
| Subarea: | Design File Settings Dialog | ||
This section contains the wikis related to the Design File Settings dialog box in ProStructures CONNECT Edition. We can open this dialog by searching it in the Search Ribbon or navigating to the Backstage File > Settings > File > Design File Settings.
