| Product(s): | ProStructures |
| Environment: | N/A |
| Area: | Settings |
| Subarea: | User Preferences |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Preferences are where you can set up the language, position mapping & view options. For the CONNECT Edition this has been shifted to the backstage.
This document will guide you on how to change the color of the background of your model’s design, sheet & drawing view.
1) Navigate to File > Settings > User > Preferences
2) Now in the Preferences dialog box, go to the View Options and set the color for the design, drawing & sheet background by click on the color boxes in front of them respectively.
3) On clicking the color box, the Color Override Preference dialog box will open and then you need to click on the color of your choice and say OK.
4) After this, click on OK in the Preferences dialog box and the ‘Save Settings’. Now, your background color will get updated as per your input.
In this manner, you can control the display of your working space background according to your preferences.
