| Product(s): | ProStructures, ProSteel, ProConcrete |
| Environment: | N/A |
| Area: | General |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to add a drawing model & sheet model view to the default layout of views simultaneously along with the default design model.
1) Open 3 view toggles in the default layout workspace of the application. Each view for the design, drawing & sheet model respectively.
NOTE – You can have a number of view toggles open as per your requirement.
2) Now, click on the arrow beside the View Attributes button and expand the View Setup tab. Now click on the drop down beside Models and choose the concerned drawing model or sheet model to have the view in the view tab.
3) Similarly, you can set up a number of views as per your requirement and simultaneously review the default 3D model along with the drawing 7 sheet model all at one time.
In this manner, you can create a number of views as per your requirement and simultaneously review the drawings generated as well as inspect the 3-D model at the same instance.
