| Product(s): | ProStructures CONNECT Edition | ||
| Version(s): | CONNECT Edition (All Version) | ||
| Area: | Customization | ||
| Subarea: |
Ribbon Customization | ||
| Original Author |
Sandip Kar, Bentley Product Advantage Group |
The user interface of ProStructures CONNECT Edition is now based on Ribbon design. The menus, menu-items, and the Tasks dialog are now replaced with a ribbon interface. Ribbons help users to easily find tools and commands with minimum number of clicks. Ribbons are organized by workflow. Each workflow consists of multiple tabs, which are organized by tasks. Sometime user need to Customize Ribbon, to add new workflow, customize the Popup etc. In this Wiki the following topics are explained
This is documented with detail explanation. Please find below link to download the document.
