| Area: | MicroStation Basics | ||
| Subarea: | Key-in Dialog | ||
| Original Author: | Roger Belen, Bentley Product Advantage Group | ||
| Updated By: | Vyanktesh Nama, Bentley Product Advantage Group |
Users who are moving from AutoCAD environment to ProStructures CONNECT Edition this Wiki will help you with the MicroStation feature which is called the Key-in command. It is the equivalent to the Command Line in AutoCAD.
To access the Key-in Browser, do any one of the following.
1. Go to the Home > Common Tools > Key-in.
2. Or one can search as Key-in in the Search Ribbon at right top corner.
3. Press Enter key to open Key-in dialog.
As a ProStructures/ProSteel/ProConcrete user, the commands that would you would need to type in is ProStructures or ProSteel or ProConcrete. Which upon selection will give you command list for other columns. For this example, I have used the Key-in > Prostructures Reload References
