| Product(s): | ProStructures SELECT series 8 |
| Version(s): | V8i (08.11.XX.XX) |
| Environment: | N/A |
| Area: | Utilities |
| Subarea: | Utilities / Import |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
In complex modelling projects, there may be requirements to attach or reference geospatial data or land terrain profiles or scanned data points of structures. This data is primarily captured by 3-D scanners in the form of Point Cloud data. This Point cloud data can be easily assimilated or attached to your ProStructures model by using the Point Clouds tool.
This document will guide you on how to attach Point Cloud data to your ProStructures model.
1) While in the model, go to Point Clouds tool in the Tool bar.
2) Now in the Point Clouds tool box, go to File > Attach.
3) You then need to select the file type of the Point Cloud data and the file. Then Open.
4) This will now open the convert the file to a POD format. You need to give a file name and Save.
5) The Point Cloud is now attached to your model.
In this manner, one can attach Point Cloud data of various different formats to a ProStructures model.
