Automatic Point Placement in AccuDraw
Product(s):ProStructures
Version(s):CONNECT Edition (10.XX.00.XX)
Environment:N/A
Area:General
Subarea:Drawing Aids
Original Author:Alistair Lobo,  Bentley Product Advantage Group
Where can one set that distance entered via values are taken over directly by ENTER ?
You need to access the AccuDraw Settings, either by
1) From Steel > Home > Drawing Aids > AccuDraw Settings.
2) Or by directly entering in the Search bar.
In the AccuDraw Settings dialog box, you need to activate Auto Point Placement.
Coordinate entries in the X, Y & Z are now taken over directly by clicking the Enter button.
