| Product(s): | ProStructures |
| Environment: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to set several snap points by default ?
If you want to set the snap functions as a separate extra toolbar, you need to select the same via the dialog by entering ‘Ctrl + T’ and activate them.
Then double click on the button to the right.
Now this will get highlighted and thus permanently active.
If other snaps are clicked, it would apply for one following action only.
It is recommended to call up these settings for multiple snap via the Search in the upper right corner in the application interface.
And then activate your desired snaps form the Multi Snap Settings dialog box.
