| Product(s): | ProStructures |
| Environment: | N/A |
| Area: | General |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to set up multiple application windows for ProStructures ?
1) Navigate to the Preferences section in the backstage. You can click on File > Settings > User
2) Now move to the Operation tab and check ON the ‘Open Multiple Application Windows’ setting and choose the number of windows you would like to be opened whenever you work with ProStructures.
NOTE – You can choose to open a maximum of 04 windows only.
3) Once you have set the number of application windows to be opened, click OK and Save Settings.
4) Then close and restart the ProStructures application. You will then get multiple application windows opened simultaneously.
communities.bentley.com/.../how-to-set-up-view-on-secondary-application-window
