| Product(s): | ProStructures |
| Environment: | N/A |
| Area: | General |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
How to enable ProStructures application for Individual Settings ?
1) Right Click on your desktop and open the ‘nView Desktop Manager’ / Applications
2) Here, you need to add the ProStructures application (which you can find at the default location - C:\Program Files\Bentley\ProStructures CONNECT Edition\ProStructures\ProStructures.exe)
3) You can also add any other Bentley applications (if required).
On adding the applications, you will notice that the ‘Individual settings…’ button has been activated and you can now set the location to open these applications windows on specific display monitors, if working with multiple screens.
communities.bentley.com/.../setting-up-multiple-prostructures-application-windows
communities.bentley.com/.../how-to-set-up-view-on-secondary-application-window
