| Product(s): | ProStructures |
| Environment: | N/A |
| Area: | General |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Not able to access ‘Individual Application Settings’ for ProStructures in Multiple Application Windows mode
1) Click on the ProStructures symbol on the subsequent application windows. Then choose the ‘nView Options’ / Menu Option…
2) Check ON the ‘Individual settings’ and then click OK to accept these settings.
3) After this you will be able to access the ‘Individual Application Settings’ to save & set up the location to open the successive application windows of ProStructures on various screens (if working with multiple display monitors).
communities.bentley.com/.../setting-up-multiple-prostructures-application-windows
communities.bentley.com/.../how-to-set-up-view-on-secondary-application-window
