| Product(s): | ProSteel 3D Professional |
| Version(s): | V8iand CONNECT Edition |
| Environment: | N/A |
| Area: | General |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
For example, several components are to be added to an assembly. When you click on the first component, this ends the command immediately.
In order to be able to select several components here, hold down the control key while making the selection.
Confirm the end of the selection with a left-click without holding down the control key.
