| Area: | Options | ||
| Subarea: | Dialog Settings |
Many users become comfortable only with the staggered dialog boxes in the ProStructures as all tabs gets visible at a time on the screen, especially if the dialog boxes have more number of tabs in it.
In this wiki, we will show you how to enable the staggered dialog boxes in the application.
1.Go to the ProSteel options by holding a right clicking.
2. In the options, click on the Dialog settings and under the options menu, check the option, 'Enable Staggered Dialog Pages'.
3. This will disable the staggered dialog boxes and all tabs in the dialog boxes can be seen and there is no need to switch the tabs which becomes tedious while modelling.
